mercruiser 3.0 lx dies out at around 2200 to 2400 rpm
lc1192
Im trying to get my boat going after 6 years of sitting. I cleaned fuel tank, put in an inline filter and all of the other filters look clean. When I start it it will idle nicely for 10-15 seconds or so then die. also when reving it up it will die somewhere between 2200-2400 rpm. I took the fuel pump off and the diaphram appears good. the stone filter in the fuel pump had a small bit of trash in it , but not a whole lot. any ideas?
big ken
Re: mercruiser 3.0 lx dies out at around 2200 to 2400 rpm
hi my guess would be in he carb, probably varnished up, caroded up etc. i would clean it out and still replace all fuel filters. six yrs is a long time. good luck
JustJason
I've never seen a stone filter in the fuel pump. They are supposed to be paper filters and there is a long one and a short one depending on what you have. Me tinks somebody put something in there that didn't belong. There may also be another filter at the fuel inlet into the carb, so check for that.
Then run this test described here....
http://forums.iboats.com/showthread.php?t=283269
