Mercruiser 3.0 oil gauge problem
trooper1954
Have a 1989 mercruiser 3.0. When running at low rpm and speed the oil pressure gauge reads just under 30, but when I increase speed it drops to zero. Anyone help with troubleshooting this? What should normal oil pressure read at say 3000 rpms?
Thanks
Install a mechanical gauge and verify oil pressure. You could have a bad sender or a serious problem
trooper1954
Thx Scott... I'm not very mechanical but would like to try and fix this myself...can you tell me what I'm looking for in the engine compartment to attach a mechanical oil pressure gauge to....and is there a specific gauge I should get for this application?
The motor is a 1990 vintage, and it wouldn't surprise me if both the gauge and the sending unit are that old too.
Thanks for your help
nola mike
You can buy any mech gauge for $10-20. Not familiar with the specifics on the 3.0, but in general you can just unscrew your sender and replace it with the mechanical. 1/8" NPT threads.
trooper1954
Thx nola mike,
I*m guessing I'll need a 1/8th extension on the oil gauge to be able to see it?
Thx
nola mike
Depends on your setup, but possibly. You could get fancy and get a tee fitting and hook both gauges up.
