Mauriceglastron
- Jun 3, 2021
- 4
Hi, I need your help with the following.
I wintered my glastron SX 175 with mercruiser 3.0 181 CID. after winter I charge oil/spark plugs /filters and started immediately. A few weeks later I wanted to put the boat in the water. It started immediately but in neutral it died. Then after I hardly could get it running. The engine was popping a lot and I got it running s few times but never stable. Then my starter died. I replaced the starter and I also found out that the cable harness was niet making good contact. So I fixed that. I got The engine running one more time and very stable. Also in neutral. After a few hours I tried again. Nog running. lot of popping noise until my starter gave up. The starter clicks and turns (high pitch sound) and also the solenoid and relais seems to be okay. ( I checked this also while disconnected from the motor). So what could be the issue? Why is the motor nog cranking white starter seems to work. could It be that the large gear had just moved so even if the starter works fine it will never get intro the langer gear. And what is causing the motor to run very unreliable and hardly get it running (popping), but if it runs it sound perfect. Thanks for your advise
