Hello everyone, I hope everyone is doing great.
I have a boat 1994 Regal Valanti 176 SE. The boat has a 3.0 MERCRUISER SN#F077854. It is NOT a closed-loop cooling.
About 2 years ago my impeller shredded and I overheated the boat. Smoke was coming out of the engine bay like crazy, fried exhaust elbows and shutter.
A week ago replaced all the exhaust elbows, water shutters, water pumps, thermostats, and flushed a system by connecting a water hose to both of the hoses at the thermostat, replaced all the bellows. I started the boat on earmuffs and ran it times for a few minutes while adjusting timing. When I checked the oil after dipstick shows 3 times as much of milky white oil.
Tested compression:150 each cylinder.
NOTE: Before I started to work on the boat I checked the oil, it was nice and brown at a normal level.
I have read a lot about this issue on this forum, could be cracked warped head, bad head gasket bad cracked block lost of different issues.
Where can I start tracing this problem?
Is it possible that when connected the hose to the said input and output of the thermostats assy I somehow introduced water into the block?
Thank you all in advance.
