Good evening all, this my first post. I recently acquired a 2006 Bayliner 185 with the Mercruiser 3. 0 and Alpha Drive. Boat has been running really well. I've had it on the water approximately 10 times after purchase and all is running really well. A few cosmetic things here and there the idol was a little rough. so I decided I was going to do a compression check and a tune-up.
The the tune up consist of new plugs wires distributor cap rotor. Rotor button I also went ahead and put in a new ignition module. Along with a new coil. So the whole ignition system is practically new still has a little bit of a rough idle but not a big deal it keeps running. but what I was changing the plugs I found that cylinder 3 & 4 had a small amount of water on the plugs. So that prompted me to do a compression check. so I got the engine up to running temperature after the tune up hooked up my compression gauge and I basically have between 160psi and 165psi on All 4 cylinders, so it's telling me it's not quite a blown head gasket. What else could be causing water to get in those back two cylinders.
Thank you for your time and your help in advance I do appreciate it.
