2005 Bayliner 185 3.0l mercruiser. Had a problem last summer where boat wouldn't turn over when key turned. Happened intermittently. Thought it was starter going bad. Replaced starter and solenoid still won't start. When the key is turned all I get is a beep and you can here a click near the starter. Gauges move when key turned. The beep doesn't stop as long as the key is turned to the on position. I thought it stopped after a second or two but I could be wrong. Also, jumpered across the started and it turned over. Any thoughts?
