mercruiser 3.0L
schooner127
I want to install fresh water cooling kit.I can't fine one that will cool the manifold,just the block.Why is that.Could I adaped.need input.
Re: mercruiser 3.0L
Ayuh,.........
I donno Why you can't find a Plug & Play system,......
But,......
Self-Engineering is a Specialty around Here......
FreeBeTony self-engineered a Complete Freshwater Cooling System for his old I6 motor, back before he traded up to the V8,+ bigger boat.......
Getting a Heat Exhanger Big enough will be the 1st step.........
A V8 sized 1 should be plenty for cooling both your Block,+ Manifold......
'course,.....
We'll be needing Alot more Info from you,.....
Vintage of the hardware, History,+ Future expected use comes to mind........
