Good day all,
I pulled the boat out to get her ready for the season and I'm having an issue. When I first turned the key to accessory everything turned on and the dash lit up and gauges moved. Turned her over quickly but did not start and then wham no more power to the ignition. Nothing on the dash light lights up, gauges don't move, starter doesn't turn. Thought it was an issue with the starter as I had an issue last year so replaced it with a spare but still nothing. Trim bilge etc. all work fine. I checked and cleaned every wire I could see. Hit the reset button a hundred times and can't figure this out. Checked wires at the ignition switch and they all seem to showing voltage. What am i missing? Is there a hidden fuse? Could it be an ignition switch or slave solenoid? Your help is appreciated.
