Mercruiser 3.7 / 470 Holley EFI Sniper.
sronza
I am rebuilding a 1984 starcraft 26ft aluminum islander with 3.7 inboard.
head has been built with new valves and long block complete. All stock.
I am adding an alternator and a Holley sniper EFI. Has anyone done the Holly on this engine.C7D82085-6959-40A1-8C0E-4ED92142F74B.jpeg
if you are going to go thru the work/effort/cost of doing a holley sniper, start with a better motor/drive
Lou C
Agreed that's a lot of cash for not much improvement.
Carbs are better by far for cost/benefit on old boats.
The only time I'd even consider that is for a boat that had factory throttle body FI and if major parts are NLA and I was the type of owner who couldn't deal with carbs. But I like carbs, I understand them so I can benefit from the much lower repair cost & better spare parts availability they offer.
todhunter
Canoeist
I didn't know Holley made this product - that's really cool! It would be cooler if it was fully tuneable, but I understand there is more of a market for self tuning EFI.
Where do you plan to mount the oxygen sensor? Do you run the system in open loop (no oxygen sensor) after the initial setup?
Make sure you post up some info / pics when you get the Sniper installed.
nola mike
I looked into this when I did my 4.3, pretty interesting. I haven't seen any threads here with anyone doing this conversion. I'd be wary of any potential power/economy benefits with a TBI system, but it looks pretty slick. I don't think any of the "keep the carb" crew has any experience with this system. That said, I'd keep the carb unless money is no object/you feel like experimenting for fun.
I did all my experimenting with all of the sniper predecessors (the Holley DFI systems) in the 90's and 00's I suggest keeping the carb
sronza
Here is why im doing this.
- I Like the concept of the Big bore 4 cylinder.
- It came with the boat and condition was good.
- reliable starting in cold weather ( i fish bay of quinte up until freezing)
- adjustable idle rpm (trolling)
-hopefully fuel economy.
-I will update post as I assemble engine.
.Additionally cost is low so far.
approx $3000 including Sniper. And fully rebuilt head with stainless valves.
- cost of a new outboard is $30 000 +
$2000.00 for engine bracket.
So what were the issues/do you not think any progress has been made in 20 years?
Back then, the electronics were unreliable, tuning was still required for every application (even if you just swapped parts).
had a custom EFI setup done with a high-end shop in Chicago for a motor back in the mid 90's. Spent $4500 on EFI only to loose 5% peak power and 7% fuel economy.
I went back to carbs.
Buddy of mine still builds hot-rods. tried Fi-Tech and Sniper a few times, went back to carbs. all his EFI projects are now turn-key LSX motors with FAST EFI
nola mike
I'm sure the electronics are light years ahead, the self tuning is cool (don't know how the O2 sensor would hold up, or if it's just for initial tuning and then runs open loop). Trying to tune a carb on a boat has been frustrating for me. Don't know anything about the fast systems, though it looks like they have a much more expensive marine system
Scott06
If you need to stab an o2 sensor in you will need something like this https://www.michiganmotorz.com/o2-spacer-stock-mercury-riser-wet-joint
i just bought one to sanity check the jetting on my boat With my air fuel ratio meter. One thing the AFR meter companies mention is for marine applications the O2 sensors don’t live long in wet exhaust. I have no first hand experience with this just something to keep in mind
agree that tuning a marine carb is trial/error and plug reading especially if you do something like build custom motor are trying to dial it in...... could add an O2 bung for tuning and then plug later.
sronza
I am a machinist by trade. I have a Bridgeport and toolroom lathe. my plan is a 1” spacer between the exhaust manifold and the resevoir/ mixing elbow. I will post pics as I progress.
nola mike
I might do that (we're going to continue to first work on getting it back on the water after its unfortunate attempt at becoming a submarine). I didn't have any luck at all with plug chops, and while they were nice and tan after the season, all that really tells me is that I'm in the ballpark a/f ratio at mid range. WOT is nearly impossible to figure out, which makes my 4bbl carb less awesome. It would be cool to see a/f out of the hole, and I could dial my midrange cruise for maximum fuel economy. I wonder how much of a difference 12:1 vs. 14:1 might make in economy despite maybe no difference in drivability.
for power (load pickup), you need to be in the 11.5-12 range.
for moderate to light load, you can go as lean as 14:1
nola mike
Right. With my plug reads, I may be running richer than I need to be and wasting fuel even though it's running well. Only real way to do this with better than "horseshoes and hand grenades" precision is with an 02 sensor.
Scott06
Perfect. On the harden one they have a couple small holes on either side of oxygen sensor for cooling, and they claim their anodizing resists the corrosion sometimes seen with aluminum on the raw water side, but may e you can find a way to keep this on the closed side of the cooling
I would machine a bore stabilizing spider for the open deck block and modify an Edelbrock aluminum ford FE head prior to going fuel injection. This would be my first step to correcting two design flaws with the motor.
