Old Yeller Boater
- May 17, 2010
- 191
Ok....at this point I'm pretty much heartbroken over this boat. I purchased an 87 Larson DC190 early last year and it turned into a real project to get things going. First step was overheating which I corrected with a head gasket replacement. That, along with an adjustment of the timing (it's got an aftermarket alternator and electronic ignition now) had the motor running MUCH better. My next step was to repair a bad water leak in the transom along with repairing the floor where the previous owner had scabbed in a piece of plywood. I finally got all that work done by a professional a few weeks ago. While that work was being done, I found that the alternator bracket had broken and I welded up a new one and now have it installed and working fine.
So now the bad news. After getting the boat back, getting the repaired alternator bracket on and getting the boat running, I have now found a crack in the block on the port side of the motor. it is just below the exhaust manifold and somewhat behind where the starter is located. My plan is to remove the starter, exhaust manifold and coolant reservior to have a good look at how bad the situation is.
Since getting the boat last spring, I've always run 50/50 antifreeze in the block and of course, it has a heat exchanger, which I drained water from prior to parking it for the season in October. Here in NC we've not had any really hard freezes so far this year and I just can't imagine the crack was due to the block freezing. That only leaves that the leak was there when I bought it and I've not been able to notice it due to all the water it had been taking on. However, is it possible when I put the head and exhaust manifold back on I over torqued or something? I used a torque wrench and did things according to the specs in the manual. I'm at a bit of a loss.
So...I realize I don't have pics yet to see the extent of the damage, but could anyone give me some ideas on what I may be facing? If the crack is not too bad, can it be fixed with JB Weld? Could I have the block repaired? Am I facing installing a new motor?
Any input appreciated.... :blue::blue::blue:
