Hello,
After rebuilding a 20' cuddy, 3.7 L 190 HP engine, and outdrive, last step was the quadrajet carb (17083522) as the idle pickups were plugged up. I also replaced the fuel pump (with the thick gasket) bottom down bowl.
On rebuild, I flooded the carb out something fierce. I figured I was still high on fuel pressure as the needle/seat had passed a leakdown test, so I installed a Holley fuel pressure regulator that holds 4.5 psi. WHen I pull the carb off there is fuel sitting in the intake and the bottom of the primary throttle plates.
DO date, I have broken down this carb probably 20 times. I have checked or verified the following:
-no leaks from pressed plugs
-secondary windup set at 1/4 turn load
-0.190 choke pulloff
-proper needles/jets/secondaries/hangers
-float set at 3/8 (I have played with 1/4" to 3/8")
-Float weight within spec
-Needle hook is no longer there, so I did not install it improperly with it hooked onto the float
-good spark
-4.5 psig fuel pressure regulated down (manual states 3-6 psi good)
-6 degrees of timing
-good compression on all cyclinders.
I have actually pulled the carb apart and tried to verify that the float does seal with water at 5.5 psi of air, which it does.
I do not know what else I can do to rule this out or fix this. Any ideas on what I may be missing here? I am at my wits end with this, and have now pretty well resigned myself to not going out this season because of this. I really regret changing the pump and carb at the same time, but now this is history and I need to try and unravel this now as I do not have the old pump any longer.
THanks in advance for your help
Ron
-good spark
Ron
