I currently have a 2 bl carb in my boat, but i have an engine with 4 bl in my garage, was told that one of the cylinders on the motor in my garage is blown.
This being said i am thinking about swaping out the carbs so that i can bring the boat from 160 hp to 190 hp. This looks to be an easy swap, pull carb and head from one and put it on the other. Do you know if it is that easy, or do i have to swap out cams, fuel pump etc?
what i am looking to do is gain a little more power, last year we had 4 adults on the boat, and 1 tuber, and it seemed to be just a little too underpowered, By boat is a 1988 stingray 210svc, dry weight is 3200.
since i already have all the parts this upgrade should only cost me a new head gasket. Do you believe i will realize an increase in power, or just an increase in fuel usage?
Any help you can give will be greatly appreciated.
