Hi all-- just bought my first boat. Its a 92 bayliner classic with a 3 liter mercruiser and an alpha one drive.
It had been sitting in a storage lot for about 6 months and hadnt been started and Im assuming that it had just been parked-- not winterized, but Im in florida so I thought no big deal.
I towed it home, charged the battery and tried to start it ( with the muffs). All I got was an intermittant click. So I pulled the plugs, tried to turn the engine over by hand ( no access to crank nut for a breaker bar) and its not moving.
I then pulled the starter thinking maybe it was bad or seized up -- but it tested good.
I put oil in the cylinders overnight to soak.
The next morning I put a small bar on the flywheel and tried to turn the engine over and I can see the pistons move about a 1/16 of an inch .... then full stop.
Im assuming that when the throttle is in the neutral position that the engine is disengaged from the drive and I would be able to turn the engine over if it wasnt seized.
Is there anything else that I missed?
Thank you for reading.
