mercruiser 3.o
robertecht
DSC_0010 (640x428).jpgDSC_0003 (640x428).jpgDSC_0013 (640x428).jpgDSC_0008 (640x428).jpgDSC_0001 (640x428).jpgI have 2 things to ask,i just picked up a1984 conroy,I think it has a 3.0 4cyl mercuiser in it,but looks to new so does the motor have an ID STAMP ON THEM. ALSO IT HAS WHAT LOOKS LIKE A OMC STINGER on it. I never owned a inboard out board before,thanks for any help.
Yankeyspeed
Re: mercruiser 3.o
The engine number should be on the side of the valve cover. You may want to post some to pics for reference. Also welcome to the site.
Re: mercruiser 3.o
welcome aboard.
post pics. if the stringer is in good shape, and well taken care of, it will last a long time. if it has been neglected, most parts are obsolete.
robertecht
Re: mercruiser 3.o
welcome aboard.
the lower end is a silver color with the top part being flat black and has a quarter gear to move the tirm
bonzoscott
Re: mercruiser 3.o
Sounds like an OMC Stringer but wouldn't have a Mercruiser Motor? Definitely need some pics. Maybe a Frankenmotor?
Re: mercruiser 3.o
could be someone replaced the longblock with a mercruiser badged 3.0
old islander
Re: mercruiser 3.o
If anything breaks on that stringer, hold on to your wallet.
robertecht
Re: mercruiser 3.o
I just put up the pic,s ,I just checked the compression it was 175 on all 4 cyl,s thanks for the help.if you can think of anything else my cell is (edit; phone number removed)
tazrig
Re: mercruiser 3.o
Robert just sent you a personal message. You will find it at the top of the page under notifications.
robertecht
Re: mercruiser 3.o
sorry and thanks ,ps. does a omc stinger have 3.0 Lx on the top of the outdrive.
thumpar
Re: mercruiser 3.o
That is definitely a stringer. On a side not. Get rid of that filter. It is not GC approved.
robertecht
Re: mercruiser 3.o
can one of you guys tell what brand of motor from the pic,s ,also Iam going to put the right filter on , thanks for the help.
thumpar
Re: mercruiser 3.o
It is a GM industrial engine but it doesn't matter what brand it is. It is hooked to an OMC so everything on the outside is OMC. If you strip an OMC 3.0l and a Merc 3.0l down they are they same. It is the externals that make it what it is.
robertecht
Re: mercruiser 3.o
thumper,thanks I was going nuts trying tofind that out , but what year I don't know,it newer then 1984 as it has e-ing
thumpar
Re: mercruiser 3.o
Is there a serial number down by the starter or on the valve cover?
robertecht
Re: mercruiser 3.o
there is a number on the intake manifold below the carb, its 8068670 ,it might just be a parts number. thanks again
Re: mercruiser 3.o
Ayuh,.... That's just a castin' number,...
The serial number will be on a sticker on the valve cover, or on an aluminum tag riveted to the block, down by the starter,...
robertecht
Re: mercruiser 3.o
ok guys,heres the number off the aluminum tag 52389 or 52889 not sure if its a 3 or a 8 in the middle of that number. if anybody knows the year let me know,P.S on the tag it said mercury marine.
