mercruiser 302 fuel filter water separater????
72fiberform
It should twist off correct? ? When I try it seems like I'm gonna break something. Is the a trick or should I just twist really hard? Scared to don't wanna break something. Thanks!!
ThomW
I believe it should twist right off. I would recommend using a filter wrench, like you would use for an oil filter, and twist it with that. Can always try spraying the seal with some PB Blaster or something. But as far as I am aware, it should twist off just like an oil filter would.
Just as a pointer, and I am sure you know this, but make sure you are turning filter the right way! Haha...if it is mounted correctly,while looking down at the unit, you would be spinning the filter in what appears to be a clockwise direction, but looking up at the filter from below, you would be spinning in counter-clockwise. I am sure you are doing this correctly, but have made that mistake myself before and couldn't understand why it was being such a bear to remove a simple filter!
72fiberform
OK I'll spray it and try again. To me it seems like the seal is glued or melted on. I'll let you know what happens! !
alldodge
But if one was installed, use a wrench like ThomW mentioned. When reinstalling coat the top rubber gasket with thin coat of oil
alldodge
dark gooey oily gas
That's not good, probably doesn't smell like gas. If it doesn't smell like gas it has gone bad.
What kind of filter was on the motor?
