My 1988 Blue water has a 305 mercruiser in it, the block is cracked, oily foam comes out of the valve covers. I need to replace the engine. But first I need to take this one out. Do I have to remove the sterndrive first? Never removed an inboard/outboard motor before.Can I remove the engine with out messing with the sterndrive? I dont know but would like to get started. All and any help or info would be greatly appreciated. Any thought on the cheapest way to go to get this thing running again, engine swap or repair this, long block, short block?Thanks in advance
