Hi All,
Got a ‘94 ski boat with 5.7 350 EFI last fall. Had sat for 10 years but seller got it running and would idle and go up to 2500 rpm no problem. When I got it I Cleaned out the vst tank and got the rpm up to wot no problem in the driveway. Never got up to temperature and found that the thermostat was installed improperly and was getting water all the time. Straightened that out and now gets to temperature. Did a compression check and was getting good consistent numbers for all cylinders except #8 which was at 45. Was advised by mechanic to rev engine and see if it was a stuck ring. Ended up freeing that up and now have 150ish accross the board. Took it on the lake for a run and would get to about 3500 rpms and that’s it. I replaced the fuel/water filter already no change. Start of the year I filled the tank with fresh gas after winter. Maybe less then 5 gallons were in it previously. Ran through a lot of that and then cleaned vst and new filter again. Boat honestly seemed to run better when the thermostat was installed improperly and was getting cold water all the time. Had the E
Serial 0F230168
Sent the ECM out to OBD diagnostics and it checked out fine. He was able to pull the engine hours 724 and logged codes which he cleared. M43 ESC M42 EST M33MAP M21 TPS M14 Coolant. Said it was good on harness with injectors and all sensors and relays and IAc was good. He did mention a lot of dirt in J1 and J2.
I borrowed a scan tool and was getting error code 42 even after ECM was cleared. I also took the below video so you can see the timing jumping around as well as some of the other readings.
https://www.youtube.com/watch?v=nqMt...ature=youtu.be
Any help or suggestions would be great. Thank you
Serial 0F230168
