After waiting the whole winter, the boating season finally arrived ! I went out with my boat for the first time this season for a short trip, everything worked well, a couple of beers and headed back home. As I left I noticed a load clanking noise just above 2K RPM which seems it came from the rear part of the engine. I immediately thought it was a gear / drive problem. I pulled to neutral. Forward and reverse engaged perfectly and engine revved perfectly to over 4K RPM without any noise at all. Oil levels of both drive and engine where ok. I decided to drive home slowly with the engine revving 1.5K (10mph) no noise at all.
The following morning my mechanic came to inspect the boat and he said it could either be a weared U Joint from the Bravo 3 drive or also the engine coupler / damper. I pulled the boat out of the water, and he removed the drive. inspected the gymbal bearing and even the U Joints seemed ok and he said its the engine damper. In short, I bought a new and changed it, launched the boat again and guess what ? ! the same clanking noise over 2k RPM came again. Unfortunately I had to pull her up again, after spending around ?1k and the problem wasn't solved. He said that it might be an upper bearing from the Bravo 3, but when it was dismantled everything seemed as new ! What else could it be ? A lower part problem from the drive ?
The engine is a 2004 Mercruiser 350 Mag MPI Bravo 3 with less than 400 hours of pleasure cruising on a 2004 Crownline 270 CR cruiser.
