kevinwatkins2003
- Jun 13, 2025
- 3
2009 Harris Grand Mariner 250 SEL Tritoon
Mercruiser 350 MAG MPI Bravo III
serial: 1A335811
300 hours
Engine misses/hiccups only in a certain RPM range around 3000 to 3500. At idle and higher throttle it seems to run fine. It only misses or hiccups in that middle power range on throttling up and when you throttle back down to the range. It is when you are getting on plane and coming back off plane. If you hold at a constant throttle in that range, it does seem to surge on rpms. Seems like im really hearing it out of the rear of boat when it missesz like the exhaust seems louder. I've had the same boat before and same setup and exhaust sounds different. No captains call.
I do know the engine possibly sit in water for quite awhile, as I see rust water lines up fairly high on the exhaust manifolds.
Local shop has had a computer on it out on the lake and ran it. Haven't been able to diagnose.
Compression is good.
Plugs/wires changed.
Fluids changed.
Not sure age of fuel, but did add 28 gallons of non ethanol to top it off and ran 5 times since with no change.
tried a new crank sensor
Checking to see if a new distributor cap was tried.
Made sure plug wires were not arcing on block
serial: 1A335811
300 hours
Fluids changed.
