2001 350 Mag MPI.<br />Took the boat out for the first time this year and would start for a few seconds and then die. Now won't start at all.<br />The fuel pump runs for 5-10 seconds and then shuts off after the key is turned to on.<br />Removed the fuel filter and very little fuel in it.<br />The filter was changed in the fall.<br />With the filter off, pressurizing the fuel tank with air does send fuel to the filter bracket.<br />Could it be a bad filter or maybe the pump running but not pumping fuel? Any other possibilities? It ran fine last fall.
