Mike Wisnieski
- May 15, 2005
- 2
Hello everyone. Ive got a problem with my 1996 Mercruiser 350 Magnum TBI inboard that has my mechanic and me stumped, maybe someone here can point us in the right direction. It starts and runs great when cold. After it has warmed up to normal operating temperature, it continues to run fine at high speed, but at idle and up to about 1200 RPM it pulsates in a steady fast-slow rhythm, belching white smoke and plenty of gasoline fumes and liquid gasoline out the exhaust. When coming down from high speed operation, it will idle fine for about 30 seconds, and then the problem mode starts. The mechanic tells me that all the basics-- compression, plugs, fuel pressure, timing, etc. are OK. There are no trouble codes showing in the computer. The sensors that have anything to do with fuel mixture have either been replaced or confirmed to be in specengine coolant temp., MAP, and throttle position. Strangely enough, this only happens while running in the river (water temp. currently in the low 50s). On dry land running off a hose, there is no hint of the problem, it runs fine at all engine speeds, both warm and cold. The last time out I tried disconnecting the engine coolant temp. sensor while it was running (idling) and having the problem. It instantly began to run fine, but within a minute it reverted back to the pulsating and the fuel in the exhaust. Thanks very much in advance for any ideas you can offer.
