mercruiser 4.3 1989 on a sea ray overheating
bajamovil
Hi guys i just bought my first boat and took it to the sea, I did a tune up before, I changed the water pump, spark plugs and engine oil, after a few minutes of running in the water the alarm sounded and noticed that the temp was almost reaching 200 so i turned it off and had to tow it back to land, Im very familiar with auto mechanics but total newbie when it comes to marine stuff, I took the cooling system apart today looking for something wrong in the system, I thought maybe a stuck thermostat or something like that was causing the prob. I was reading in the posts about impellers, does my engine on the outside part have an impeller? or only the water pump?, i noticed 2 bilgie pumps 1 its on the floor below the engine i turn it on and it takes the water of this compartment and there's another one out side the boat close to the outside part of the engine, what it this pump for? its not conected to n e switch it runs 2 cables to the batery compartment with little pliers, all the help will be greatly appreciated, i dorve 2 hours to put it in the water and the 1st experiance was a failure, I have the boat in my shop and puted a big tank and sumerged the peropeller inside the tank how do i test the cooling system with out going to the sea again?
bob58
Re: mercruiser 4.3 1989 on a sea ray overheating
The best thing you can do is buy a Repair Manual for your Motor/outdrive HERE <br />It will show you how to replace your impeller, plus so much more. They are worth there weight in gold!<br />The impeller should be replaced every couple of seasons.<br />If the boat is started out of the water, you will toast the impeller in seconds!
rodbolt
hello<br /> yep if you started it on the trailer for just a min to see how it ran the impeller is toast as well as the upper and lower housings. buy the upeer and lower pump kit replace it and keep cruising. but you may wish to buy and study the manual. next post someone may ask what the part number is for your manual so they can help<br /> good luck and keep posting
JB
Moving to I/O
