Re: Mercruiser 4.3 alpha 1 steering play- is this excessive
Sounds about normal.
Among many things that cause the wandering, one of them is you.
Unlike a car with tires that do not slide sideways, a boat will not stop turning when you center the rudder.
Consider you want to turn a bit to the Left.
You turn the wheel Left and when the boat is headed in the proper direction you center the wheel.
But the boat keeps turning and eventually takes a heading too far Left due to the inertia of 3000lbs sliding sideways in the water.
You then turn Right to correct the overshoot and end up too far Right!
And so it goes, Left, Right, Left, Right.
To correct this, just before you reach the desired heading you need to to turn a little to the opposite direction to stop the turn and then back to center to hold the heading.
A little practice will let you determine the amount of opposite rudder needed to stop the turn.
