mercruiser 4.3 alpha one outdrive loose
mgeorge15
I have noticed lately that my outdrive sounds kind of noisy. If you turn the steering wheel while its idling it goes away in certain positions. With it out of the water it is loose you can move it from side to side very easily but the steering wheel doesnt move. Any help would be great!! :D
achris
More fish than mountain goat
Re: mercruiser 4.3 alpha one outdrive loose
Loose upper swivel shaft clamp in the gimbal ring. Tighten the two bolts (you'll need a spanner on the nuts on the back) at the top of your gimbal ring. Should be done on the annual sevice, that's every year.<br /><br />Chris.......................
mgeorge15
How exactly do you do that, where are the bolts at, im not to familiar with outdrives. What is the gimbal ring?
garycinn
ooooh, oooooh, I know, I know. Pick me!!!<br /><br />I'm not DonS, but I do play one in real life. How about #21 & 23 in the pic below? Am I right? Am I right?<br /><br />
Ayuh,.........<br />#1 is the Gimbel Ring,......<br />And #21,+ #23 are the Nut,+ Bolt.........<br /><br />You get an A+ ,garycinn.......... :D
garycinn
Originally posted by Bondo:<br />You get an A+ ,garycinn.......... :D
Thanks, Teach!<br /><br />A couple of years ago I couldn't spell sterndrive, and now I are one.
rodbolt
unless #13 or 14 is worn out. then the fun begins :)
Ayuh,.............<br />Lota Work to get a Wrench on #17........ :rolleyes:
