I'm new to boating. Bought a 2002 Bayliner Capri, Mercruiser 4.3 V6 with Alpha One drive. It won't shift into gear now, forward or reverse. I've done a lot google searches so I hope this post makes sense. Don't assume I know what I'm talking about. You may want to "dumb down" your responses.
Boat was prep'ed for new season by a reputable boat mechanic back in April, used it maybe 20 hours since then. The last few times I've taken the boat out, I would shift into reverse and not hear the gear engaging, the prop would not spin. I'd move the throttle back to neutral and try again a few times and then the gear would engage. About a week later I hit a shallow spot in the lake, stainless steel prop drug about 5 seconds (I didn't know to shift into neutral, but do now!) on rocky bottom. Edges of prop are rough now. Next few times I took boat out, same behavior with the throttle to engage engine. Then last time out I was going about 15 mph and the gear disengaged and the engine rev'ed, coasted to a stop. Could not get gear to engage, had to get a tow back to boat lift.
I then ran engine on boat lift as a test. Water pump is working (water coming out). I guess that means the drive shafts are turning which means the coupler is maybe ok, but I don't know. I put throttle in reverse a few times and got nothing, not even any ripples in the water from the prop, then the prop did start turning last time I did reverse. I took cover off engine and the gear cables do move the that "lever" back and forward when I move the hand throttle forward and reverse.
This feels like the gear cable linkage is loose somewhere. Or might I have a spun hub? I will call a mechanic for a house call but just want an idea of what the problem is, maybe learn a few things too.
Also, can the prop blade edges be straightened and balanced? Or just buy a new prop? Mine is a Mercruiser Marine Vengeneance, 3 blades. Numbers on prop are 48 16316 19P and I don't know what those mean except the 19P seems to be the pitch. If I need a replacement prop, is there a better choice? Thanks!
