jeremyk2000
- Apr 17, 2012
- 1
This is my first post, but this forum has been SUPER helpful for me over the years in doing my own boat maintenance and repairs. Don S. has helped me on numerous occasions over the years! RIP. Thanks to all who help in this forum! I try to do as much as I can myself, but I do have mechanics in to do things that scare me and I don't fully know about even after reading up on them.
So now to the issue(s). I had a little bit of water in the remote oil filter when I changed the oil in the fall. At the same time, I was just having starting issues with this engine. The manifolds/risers were replaced two years ago and they had to come off due to other work last fall. Upon inspection, they were clean, no rust spots in exhaust passages and the water passages were also looking fine. Plan was to run boat a few times and change oil.
Ran boat July 4, first time out due to other issues - boat only put in water on the 1st. Already off to a very bad season. Loud sounds coming in from the day, first issue was cracked U-joint bellows, took on water had to get emergency pulled. That annoyed me because I had a mechanic change it last season. Friends and I changed it this time around. Changed bellows and gimbal bearing.
Boat back in July 18. I am based in CT, we went over to Long Island for the day, 45 minute cruise. Docked boat went into town for about two hours. Boat starts right up, cruise back no issues. Next weekend try to start same engine that had a little oil in it and starter was really being challenged. Take plug out port side towards transom about 4-5 ounces of water comes out, a little on the other two. The starboard side ones out, not a ton of water but plugs all rusted and looked to be a little water on the plugs anyway.
Take manifolds/risers off. Water in exhaust both sides.
Now I am getting to the point where I need help so I had a mechanic come down and I explained the above. He says tuliped valve and I need a new block. Keeping in mind I have not taken the heads off and inspected inside I just wanted to get thoughts. He says after water gets in the engine it is junk anyway. I suppose true? It cranks now that plugs are out and I cranked out water and dumped two bottles of wd40 into the valves. I also changed the oil and cranked it as well.
Just wondering if there is any chance I should dig into this more or give up and listen to him. Would be great if I can replace head gaskets if that is what it is and be OK. I have no idea if this tulip theory makes sense based on the above or if a blown head gasket makes sense so wanted to see what you all thought. This boat did overheat once about 3 years ago when a piece of the raw water plastic casing broke and completely ate the rubber impeller. Freak accident. No other overheating or odd operational items have occurred other than the non-start issue which I noted above.
Mercruiser 4.3L EFI
Year 2000
Serial # OL623728
Mercruiser 4.3L EFI
Year 2000
Serial # OL623728
