Mercruiser 4.3 Engine Swap...Please Help.
baron119
Ok hopefully someone will be able to help me with this question. I have a 1993 Sea Ray with a Merc 4.3 (serial number OF121304). I need a new engine and I found a 1992 Merc 4.3 (serial number D823678) Is there anyway to find out if I can swap these two engines without any issues? My current engine has a crack on the starter mount. The engine that I am looking at is drop in ready. Thanks for any advice or info.
baron119
Re: Mercruiser 4.3 Engine Swap...Please Help.
do both of these engines have a balance shaft?
imported_TheMan
You will have to tell us that..
The blocks from '92 and on have the balance shaft.. if your block is a true 92.. maybe. if its from 91, no it won't.
baron119
I received an email from the marine yard that has the 92 and they say it is an exact fit, so I guess my next question would be, if it does not have a balance shaft is it a deal breaker?
Thanks for all the posts
180shabah
Deal breaker? no tif the price is right. It'll just shake a little, most noticable from 1200-1800 RPM. Most boats don't hang around in that range for long.
Ayuh,... Bolt it in,+ Go Boating.....
