Mercruiser 4.3 front engine mount screw hole repair
darius333
Hi everyone,
Is anyone could give me any ideas how to repair stripped front engine mount screw hole at the stringer? Many many thanks
tpenfield
Check the hole in the stringer to see if it looks/feels wet or rotted inside. If it is dry, (really dry) then you could fill the hole with some epoxy and then re-drill the hole.
Rick Stephens
I did the last one by drilling out the hole larger and then filling with resin with some shopped strand glass in it. Give it a little more strength than straight resin.
Like tpenfield stated, if the wood inside the motor mount/stringer is wet or rotten, you can't fix it this way. You'll need to evaluate the state of the wood up and down the stringers and across the transom before knowing how to proceed. You will end up ripping apart your engine coupler if the wood is rotten.
the fix is determined by the type of failure.
if the hole is dry, see above (you can also drill over-sized and drive in a section of ash dowel)
if the hole is wet, your into a restoration.
Ayuh,...... Welcome Aboard,.... What they said, ^^^^
