riodecolumbia
- Jul 2, 2019
- 5
I’m still relatively new to the boating scene, but I’m figuring more and more things out as I go. I have a 1991 Regal Valanti 190 boat with a Mercruiser 4.3L inboard motor in it.
So the motor will work completely fine for like 45 min or so, but after that it begins to experience a problem. The motor will all the sudden drop about 600 rpm or so and then climb back up to where it was at. Sometimes it won’t make it back up to the original rpm it was at, and keep going slowly down until the motor will die. If you wait a bit the motor will usually get started again, but won’t be long before it dies again the same way.
It has a rebuilt carb, and I thought originally the float was getting stuck maybe but the carb is getting plenty of fuel it looks like and seems to be tuned fine. I checked the amount of fuel in the tank, and it has plenty of fuel as well. I replaced the fuel pump with a new one also, but the problem still seems to be occurring. I was thinking that maybe it may be an issue with something bad in the fuel tank itself, but I don’t know.
Any help would be much appreciated!
