Mercruiser 4.3 fuel pump
Status
Not open for further replies.
JJJ
Hi, mine died. So I am thinking of going with a Holley red pump instead of the replacement merc pump. Any pros or cons? Other than adding the vent tube and relocation. Thanks<br />Jeff
bluewater19
Re: Mercruiser 4.3 fuel pump
What year 4.3?<br />Holley red pump is for a car. Get one coastgaurd certified or you'll be sorry.
What's the matter with the OEM pumps,..???<br /><br />They Usually fit perfectly,......<br />You Don't need to build a Mounting Bracket,....<br />The Plumbing Matches,.....<br />The Wiring,.. Plugs In,......<br />Everything is Marine Rated,....<br /><br />I Can't think of Any down-sides,.........
JJJ
This red pump is marine rated so that is covered - only difference is the vent tube to the best of my knowledge.<br />As far as why not merc., well cost is one. Also the pumps have been superceded a few times which indicates problems at one time. And a wiring change is needed either way - new merc pump connector is different.<br /><br />It is a 96 Cobalt 4.3LX.<br /><br />While here what is the difference between early 96 4.3LX and later 4.3 LXH? Both are 4BBL carbs, pumps are the same, but belt setup is different and other small things. Both 96 Cobalts.<br />Is one carb bigger than the other? One uses manifold heat for the choke, the other electric.<br /><br />Just wondering if they are different HP motors or just early and late?<br />Thanks,<br />Jeff
180shabah
don't play with your fuel system. Suck it up and pay for marine parts. You and your boat will live longer.
JJJ
Why isn't marine rated the same, no matter who makes it?<br />The main difference in pump is that <br /> The merc, you throw away if it goes bad.<br /> The holley is rebuildable and is a vane design which is more tolerant of any debris over the gerotor merc.<br /><br />Not that any debris should get past the water seperator/filter assembly :) <br /><br />I would much rather have a mechanical pump, but there isn't a space for one.<br /><br />Also this boat sits probably 11 months a year, used mainly for snorkling in the keys once a year. Then other small infrequent trips. Not sure if that is hard on the fuel pumps or not?<br /><br />Any tricks for keeping condensation in the tank down???<br /><br />Jeff
bluewater19
If The holley is marine rated go for it.<br />What do you need a vent tube for on a electric pump? My 2003 4.3 doesn't have one.<br />Keep your fuel tank full and use a water seperator.
milkyway
To minimize condensation, is it good or bad to put a tape on the vent while the boat sits on the driveway?<br /><br />Having the tank full all the time makes the boat less gas-efficient when I need is only 1/3 most of the time per trip.
JJJ
Here is what it says for the pump<br />"Holley Red Pump 97 GPH Free Flowing Factory Pressure Pre-set at 7 PSI<br /><br />The Holley fuel pumps meet USCG requirements and are a great reliable fuel supply for any marine engine. Each pump includes a mounting bracket and fuel/fume vent tube. These pumps weigh less than 3 pounds and come with 3/8" NPT inlet and outlet provisions."<br /><br />Already have a fuel/water seperater on it, I think. Looks like an oil filter?<br /><br />I thought keeping full was best - similar to my skiis.<br /><br />Is dry gas a big no no if it is put in and the tank run out that day???
achris
More fish than mountain goat
Difference between the LX and LXH is a lot more than the belts on the front!<br /><br />They have different heads (not interchangeable) a different cam and different pistons, to start with a few.<br /><br />Chris................
JJJ
Thanks, I was curious. It seemed the LXH had much better topend power.
achris
It should do, it's got 20 ponies more! <br /><br />On the subject of the fuel pump. Please put a genuine one back on. Nothing worst than trying to work on an engine that someone has 'butchered'.<br /><br />Chris............
JJJ
achris, what is the difference between the heads? Are there different Vortec heads? And if so is the performance that different?<br />Thanks
achris
Originally posted by JJJ:<br /> achris, what is the difference between the heads? Are there different Vortec heads? And if so is the performance that different?<br />Thanks
Don't know exactly,<br />Yes,<br />Yes.<br /><br />Chris..........
av8or09
JJJ<br /><br /> I used the RED Holley marine pump on my boat because the motor on mine was replaced with a short block meant for fuel injection and did not have an option for a mechanical pump as originally used. This pump has worked almost flawlessly for three seasons of heavy use. My only problem was the pressure relief plunger needed to be replaced once (kit cost $7.00 from ADVANCE AUTO {yes they do sell some MARINE parts if you know the part #'s and look them up on the web site}) An hour later the pump was back in the boat and working perfectly!! As for the vent line, that is in case of an internal pump failure, gas will be dumped to your carb and not into your bilge as I understand it. There is a vent tube connection on the back of my 2V rochester that was hooked up from the factory from the mechanical pump for the same reason. As far as the original being better than the replacemnt, I cant say, but I do think "DONE CORRECTLY" that the Holley is a good option.GOOD LUCK!
JJJ
It is on order. <br />Thanks
aldorino
Hello I have a Bayliner 2050 year 1990 whith mercruisier inboard motor and alpha one propeeler. The motors is a model MCM 4.3 litre Lx (V6) engine serial 0D852371 drive serial number 0D880327. I need electrical fuel pump. My pump indicates SAE J1171 Marine Parts and this indicates in a stamp number 952 2042B, made in usa. I need you indicates if you have this parts or equivalents Tanks Best Regards Aldo Caiozzi Santiago, Chile
achris
Use any Merc dealer and the part number for the pump is -805656A2.
The labels "SAE J1171 Marine Parts" is just a marine standard label..
Chris..........
Don S
You need to start a new thread of your own.
Status
