Mercruiser 4.3 just clicks
Wellcraft170
Tried to fire it up this afternoon and it just clicks.
Any ideas why? and not cranking/turning over?
video attached
if the cables are loose, the connections corroded, or the cable is funky full of corrosion (green).
clean all the battery cable connections with 300 grit sand paper until they are shiny enough your mother would eat off them
tighten all the connections with a wrench (any wing nuts should be replaced with real nuts)
seal all connections with marine electrical varnish
Wellcraft170
Thank you for the input. I will try all of that tomorrow and give an update afterwards
