stresspoint
- Sep 19, 2022
- 1,050
first off my 4.3 is a bitsa so model number is irrelevant , however the 2011 engine block and the wiring is OEM to a 1999 Maxum SR 1800 both engine and hull.
yesterday on an outing the motor was running fine with all gauges working for the most part of the day till i shut the motor off for around half an hour , on restart i noticed " no oil pressure " on the gauge , no alarm warning , fuel pump is switching on , oil on the dip stick is a little low as per usual as , that comes up once the motor has been stopped and the stick pulled to equalize sump to the tube.
so i figure WTF plenty of oil motor seems fine no knocks , rattles or alarms , must be a gauge issue so we continue to boat for the next hour or so and it is running fine hit the 5500 rpm limit a couple of times.
moving forward : today i checked the gauge , wiring and sender , all checks out fine.
now i am concerned as this is a reasonably new rebuild with a lot of performance mods.
so , i top up the oil to recommended level on the stick (added about 500ml) and fire up the motor , @ 2500 RPM on the muffs the oil gauge moves slightly and returns to 0 when the RPMs come down to idle , noting out of the ordinary as far as motor noises go , very quiet and smooth .
so with info provided what do you guys suggest to do next next ,
I'm still on the fence regarding the gauge , but I'm not sure now after it moved that little bit @ 2500 rpm. but i am not going to risk the motor just in case.
