Mercruiser 4.3 tks leaking water
Status
Not open for further replies.
kjp17
Water is leaking on my 2010 mercruiser 4.3 tks into the bilge from the left side above the bottom drain plug. Thats the best i can narrow it down. Any suggestions?
dubs283
Re: Mercruiser 4.3 tks leaking water
was the engine winterized??
not enuf toys
2010 boat? does it have the original bellows on it?
dubs283
no, but i did drain the motor before winter
okay, is water leaking from the engine near the engine drain plug?? while it is running??
or is it leaking from the transom assy area near the hull drain plug while in the water??
can you post a pic of the leak??
kjp17
i cant get a camera up in there to take a picture, it is leaking right above the drain plug, it is in driveway with ears on it
dubs283
leaking above the engine drain plug while running??
if so - cracked block or pushed out casting plug, cause = not winterized
use a mirror and flashlite to investigate the source of the leak
when you drianed the block did you poke a wire in the drain hole to clear debris??
kjp17
pic needs to go 180d right
dubs283
im guessing the pic is upside down, if so it looks like the casting plug behing the motor mount popped out
you'll need to remove the mount to replace the plug, then run the engine to temp for 10 mins, let the motor cool/heat soak and run again and check for water in the oil
kjp17
think i just found it. Is it a metal cap looking plug?
gergAlicious
Going through mine now. Engine on stand.
Here is the port side of the block. The left core plug is the one behind the motor mount. You can see the three threaded bosses the mount attaches too:
Here is the starboard side:
This is a 2004 engine. The small boss, down low between the core plug locations is where the block drains were screwed in. Actually to the rear on the port side.
And . . . I see it was an original post from 2014 . . . . :)
Status
