Just recently got my first boat and took her out on the Potomac on Sunday. Started up fine initially but after we dropped anchor and fished for a while, when I started her up it was very difficult to restart. I finally continued to turn the key while "pumping the gas" (with the shifter) and it made a loud shrill after cranking. Afterwards I had to do this every time I restarted the boat. What should I check first? I understand that it is a carb motor but I'm concerned that I will eventually burn out the starter with as long as I am turning it over before the engine starts. Any suggestions would be appreciated pertaining to this issue. Thanks. Reg
