Mercruiser 4.3 will not start
frig770
2004 mercruiser will not start, turns over starts and as soon as starter is released engine shuts down. If I keep the starter engaged engine will run. Replaced and checked oil pressure switch, Switch is working fine. Power to fuel pump drops off after dissengaging starter. Ingnition switch replaced also and tested. Anyone have any ideas?
alldodge
Welcome
Could use a bit more info like a serial number to help but being a 2004 is it fuel injected ?
Check the key switch and MOB switch
alldodge
Thanks
Being it's a carb it should be your key switch
frig770
New key switch. First thing i tried. Going to check wiring from switch again.
alldodge
Unless someone changed the wiring (doubtful) it has only the one purple wire powering the ignition.
dubs283
Still no confirmation of the lanyard, run/off, man overboard switch at the remote
First post sounds exactly like a situation where the switch is in the "off" position
Scott06
This is the symptoms of the man over board switch being tripped. Red toggle on shifter cycle it
Ayuh,..... Welcome Aboard,...... Another possible problem spot could be corrosion in the cannon plug, specifically the purple wires pins,....
nola mike
Agreed, gauges should be unpowered with ignition switch on if so
alldodge
Check voltage at coil for 12V with key ON and motor OFF.
If power is not present then trace the purple wire back to the key
For a quick test, run a jumper from the purple wire on the key to the coil, it should start and run
