Mercruiser 4.3 won't run after 20 minutes
cdkuefler
Boat: 1999 Chaparral 1830 Sport<br />Motor: Merc 4.3 Litre V6 EFI<br />Drive: Mercruiser Alpha One <br /><br />Another vacation... down the drain. Took the boat up to a cabin we rented about 3 hours away to wake board and water ski.<br /><br />Day 1: the boat ran fine for 7 hours but on the way in it started misfiring badly and we had all we could do to get to shore. When we returned to the cabin I checked all the plug wires and fuel filter and everything seemed fine. <br /><br />Day 2: Took the boat out and after 20 minutes the motor started misfiring and we aborted our trip. Took the boat to a marine dealer and they checked it out and noticed that the carburator settings were off, tested it in a tank and on the water and $40.00 later I had my boat back.<br /><br />Day 3: We took it out and 20 minutes later the same problems came up. At this point I called our mechanic and he suspected ignition system problems based on the 20 minute delay factor. <br /><br />Day 4: We decided to head home to have our dealer look at it and our mechanic confirmed it was a faulty distributor that was causing the problem.
magster65
Re: Mercruiser 4.3 won't run after 20 minutes
Saw the same thing happen with bad risers. The moisture would build up in the cap rather quickly causing it to misfire.
cdkuefler
After picking up the boat today they told me it was a $40.00 sensor that was bad, I would assume with the ignition system. Took the boat out 4 hours and it runs great.<br /><br />Yippe...
