boatstuff123
- Jun 4, 2020
- 10
Some background: After completing a 2 hour boat ride, the tide had gone down and I had to load the trailer in shallow water. During the entire trip, the temp was at 160F. I attached the hose to the lower unit through the ear muffs and went to flush out the salt water. The Problem: There was NO water coming out of the exhaust ports. The temperature creeped back up to 160F, but then continued to 175-180 with no water coming out of the exhaust ports. I stopped the engine. I removed the thermostat and all 4 hoses had no water in them. The thermostat was debris free. I suspect I sucked something up in the shallow water. I had thought even with a worn lower unit water impeller, that the pressure from the hose would circulate the water, leading me to believe there is a blockage. Thanks in advance!
