bluewaterboater
- Apr 24, 2011
- 37
I have been having some issues for a year now with my engine in my Sea Ray 190 BR. The boat is going into the shop next week to have a go over and I thought I would get some advice here before it goes. The serial number on the engine is 0L092324
The problem:
When I push the throttle all the way down the engine gives off a popping noise and it hesitates. When I ease off the throttle it goes away. Going 35mph or so is not an issue, it only happens on the high end of the speed. This is an intermitant problem and I have had the boat full out in the range of WOT and about 48mph.
What I have done so far:
This is NOT a prop issue. I have a SS 21p prop on and I have also tried a 23p prop and the results are the same. The boat IS propped correctly. Like I mentioned above I have had the boat at WOT and no issues.
Compression has been checked on all 6 and is good.
Spark plugs and wires have been changed.
Rotor and cap have been changed.
Fuel/water separator has been changed.
The boat starts, runs and drives like a dream all the time and has never let me down. My only issue is on the high end of the rpms and speed. When this problem happens my rmp gauge just goes stupid and starts bouncing all over the place but I don't know if this is related to the problem. Could it be the fuel pump? Does a fuel pump work or not or work but not enough fuel?? Could it be the rev limitor acting up prematurely??
Thanks for any help that you can offer
The problem:
