2002 4.3L V6 Mercruiser 190HP serial number 0M092704
Engine will not crank. Last used boat 3 weeks ago. I turn the key and get a single click from the starter relay switch beside the 50A breaker. Kill switch is in RUN position. Battery is a month old 12.6V, terminals are clean, wires secure. Hand throttle is in neutral. 50A breaker has 12.5V on each side, was replaced 1 year ago. Blower and bilge rocker switches have power. Starter relay switch (slave solenoid) is now new since I thought that was the issue, still get a single click when I turn the key (ugh). Engine was slow to crank this summer. After warm up, it would crank right over again. Lake is fresh water, not salt.
I'm suspecting the starter solenoid or starter or corroded wiring/connectors at this point. The orange wire into the back of the alternator has 12.5V. I will test both sides of 90A fuse for 12.5V soon. I plan to remove wires from starter solenoid (if I can reach them!), clean them. Any other advice? I am not original owner of boat but I suspect the starter solenoid and starter are original. How do I "hot wire" the starter solenoid and starter to test engine for any crank at all? Is there a obscure fuse somewhere? Any other ideas?
And do I have these wires labeled correctly? Thanks.
