tony203040
- May 11, 2016
- 7
Hello everyone,
Thank you in advance for reading my post. First time post for me on this forum...any advice will be greatly appreciated. Here are the details of my issue and my troubleshooting steps.
Equipment Details: 1995 Mercruiser 4.3LX (GM) with 4 Barrel Carb (Alpha One Gen II Outdrive).
Engine SN: 0F296848
-Antonio
Engine SN: 0F296848
- Engine does not start
- Engine will rotate during key turn, but will not start. Initially the “turn” is very slow and slowly ramps up to a speed I would expect to see the engine start. Potentially bad battery, but I only attempt to start while jumping from a truck.
- Verified Spark
- Checked input to distributor cap ~12VDC.
- Checked output of one spark plug wire; reaching 12VDC (as expected)
- Fuel Checks
- Checked carburetor and cannot see fuel spray from the jets.
- Manually added gas to carb, engine started for a quick second.
- Found damaged (dented) fuel pump; replaced fuel pump as a precaution.
- No change in symptoms.
- Disassembled carburetor and cleaned internals. Then replaced the cable connectors at the battery terminals.
- Engine would then start; but with a slight roughness and varying idle.
- Go on vacation for 10 days; engine no longer starts when I return (same symptoms as original problem).
- Replaced oil pressure sender. Now, I can hear the fuel pump running…not sure why I didn’t hear it before.
- Disconnected fuel line from carb input; attempted to start; fuel is DEFINITELY flowing to the carb (from the pump).
- Reconnect fuel lines; looked in barrels of carb; still not seeing any spray.
-Antonio
