I have four blocks (two in the boat, one of which has a bad starter), all serial numbers 67XXXXX", so, from what I can find that makes them 1983-1984. If the picture shows up, this is a picture of one of the starter mounting studs. I can get wrenches on the nuts but both are rotating with the pin/bolts. There are not bolt heads on the back of the flywheel cover. I've rotated both nuts and bolts atleast 4 revolutions each - they are not coming out - so if they are threaded, they are stripped. If they are pressed, I guess the same. Well, guess I have to haul the boat, and pull the engine so I can get at things to repair them. The fun of old boats.
