DBEE When you pull the engine out, it's not a total overhaul, it's just pulling the engine out...
I'm sorry we couldn't offer you the advice you wanted to hear. You came here asking if it was possible to pull a piston without removing the engine. Many people, myself included, have offered you our honest, EXPERIENCED opinions. Many of us do this for a living. Trust me, if it was easier, that is the way we'd do it. It's not, so we don't. The faster, easiest and cheapest way is to do what you don't want to hear us tell you.... Pull the engine.... Pulling the engine is a 2 hour job, refitting it is about the same. Any time in the interim would be less than you would spend trying to get things out, and back in, that you can not see. You will spend more time fiddling around with the engine in the boat than it take to R&R the engine. And after 4 hours of not succeeding, you will decide that you need to pull the engine. BTW, cost of parts and gasket to R&R the engine? $0.... Yes, $0.....
What's involved?
Remove the drive (10 minutes)
Disconnect the fuel line and main electrical harness plug (5 minutes)
Disconnect main power feed at the starter motor (6 minutes because sometimes they are a bit deeper into the bilge)
Disconnect throttle and shift cables (5 minutes)
Loosen rubber exhaust boot at the bottom of the exhaust elbow (2 hose clamps. 3 minutes)
Remove 2 rear engine mount screws (sometimes hard to access, so 5 minutes)
Remove 2 front mount lag bolts (any more than 2 minutes and you're 'slacking;')
Hook up a 2 leg chain lifting sling. (lift points are mounted on the engine, 3 minutes)
Lift engine.
Pull the boat out of the way and lower the engine to the floor.
Chris.........
iboats moderator.
I will not close this thread, in hope that you come back and continue to be an active member of this community...
