mercruiser 470 & 488
lynnboy021
my bro in law's 470 motor is running at 190F is that to hot cuz my 488 runs at 140F?? on my 488 my motor oil is new and right on the full mark and on my oil gauge its at high, so is my oil sen bad or my oil pump is going bad and also i have a new head gasket and manifold gasket but i am low on coolent but the tank is not sucking coolent from the rev tank???/
backyard mechanic
Re: mercruiser 470 & 488
Slow down there Lynn boy... Too many questions not all relate to original Q. As for a 190 temp over a more normal 140 temp... He could have swapped his thermostat to a higher temp range. Your 140 thermo is what the factory suggests. Just because the engine is FW cooled, the higher temp (thermo) will cause the raw water to raise up in temp. I hear that salt separates at just above 160 I think... He will have a better chance to have (elbow) salt build up than you.
Oil on the fill stick (if factory) is where you want to settle. The sender may say "high" but that is most likely oil pressure not level. Not likely anything is going bad that I could tell you about w/o looking.
OK, so you are low on coolant but it's not sucking from the reservoir? Is the oil level growing or changing color? When running after its warm (thermo open) do you see air bubbles coming up with greater RPMs? Maybe your coolant is swapping sides- going into raw water. Why it isn't sucking off the reservoir is a vacuum issue. Maybe a pressure cap or a leaky hose issue. Pressure testing will tell you.
lynnboy021
thanks bro ya i know there is oil i just dont want to be out in the open and the motor wont turn over cuz oil pump was not pumping.
