Mercruiser 470 cam seal ????
jstaguy24
My new cam seals arrived today and im ready to start re-assembly tomorrow. The new seals are different then the old ones I removed.The old ones were the same on either side so the seal was identical no matter what direction you put it in. The new ones are solid on only one side and the other side is hollow and you can see the spring wrapping the seal. Im not sure which direction to install these. My guess would be to put the hollow sides on the inside (both sides towards the seep hole so one side seals out the oil, and the other seals out the water. But im not sure. Anyone who has done this repair and can let me know which way to put them in it would be appreciated
Thanks
Don S
Re: Mercruiser 470 cam seal ????
This from the service manual that you can download from the adults only sticky. You want manual #3.
attachment.php
stonyloam
The function of the second seal is to keep any coolant that seeps past the first seal from entering the crankcase, so both seals face the water side. Any coolant that gets past the first seal is blocked by the second, and leaks out of the weep hole.
stonyloam
The convention is that the spring side should face the liquid being contained (pressure side). That is the springs (hollow side) on both seals should face the coolant (away from the engine). That always confused me too:confused:.
jstaguy24
Dangit I put them in backwards then. I put the solid side facing the water side figuring that would be the most solid part of the seal. I hope it holds. Might as well try it now that its together. Just waiting for the sealant to dry and then I'll test it
Don S
I hope it holds.
It won't ! You WILL get antifreeze in your oil. There is no oil pressure against the seals, there is water pressure, it will leak as soon as the cooling system starts building up pressure.
achris
More fish than mountain goat
Agreed. Take it off and start again. If you don't, then you will be doing it anyway, but this time you'll be cleaning water out of the engine oil too....
Chris......
stonyloam
Dang here too, sorry I was so slow getting back, had to do some research to make sure I knew what I was talking about (not always the case:rolleyes:), then reread your post and thought Hmmm.... that could go either way:confused:. I agree, better redo. Better safe then (really) sorry.
jstaguy24
Thanks for the help guys. I got it switched around the right way this time. Thankfully I can do it all in place and dont have to pull apart to much
