Dayrunner567
- Jul 30, 2009
- 9
I have a 1981 Four Winns w/ Merc 470 I/O. Just picked it up. checked all fluids and is clean and good. After running great for about 45 minutes it stalls. It restarts everytime and will rev up with no load on it. As soon as I put it in gear to go it dies. I can slowly put in gear and as it just catches, it will go slow. Any more throttle it will die. I check fuel filter and looked clean but old. I changed it. Put an in-line clear filter so I can watch fuel flow. I rebuilt carb w/ new needle and float. It is still doing the same thing. Fuel pressure is 8-10lbs, the spark seems to be weak. I changed the original plug wires from 1979 that the resistance was really high. Changed the points, condensor, cap, and rotor. Plugs look new. How much spark should this produce? I have an in-line spark tester and the max setting that I get any spark is less than 10k volts. And even then its a hairline blue spark that is hard to see. Same thing coming straight from coil. I did not put a new coil on it yet, but I put a used one that I think works. Does same thing as other coil. Disconected the tach to see if shorted and was no improvement. Does anyone have any suggestions?
