mercruiser 470 exhaust riser blanking plate
overture
Hi,
I'm replacing the exhaust riser on my engine (470 with the heat exchangers). When I removed the riser there was a steel blanking plate, I guess to keep the raw water separate from the fresh. However, my new replacement plate has a small hole, about 1/8". Is this a modification or have I got the wrong part?
The new plate is an original Quicksilver part - Plate-Exhaust #60207
Hope someone can help, thanks..
Re: mercruiser 470 exhaust riser blanking plate
Ayuh,... Correct,... Wrong plate...
