Hello all,
I just purchased a 1986 Wellcraft 190 American fitted with a Mercruiser 170HP 3.7l engine. The boat would crank but would not start and I discovered that I was not getting spark to any cylinder. Removing the distributor cap, I see it was outfitted with the OE points system. Coil tested alright as far as I could see so I decided to just upgrade it to the Pertronix Ignitor II and Pertroinix II coil. I did remove the purple resistor wire from the choke and just put a jumper in from the battery to the positive terminal of the coil just to test the system. After replacing the components, I got spark and the engine started up. WhenI went to adjust the timing, I found the engine would no longer start. After testing, I found no spark again?!?!!?!?!!?! Thought the Ignitor II hall sensor may have gone bad, so I replaced it with ANOTHER new unit. Same thing happened, got spark, started the engine. Disconnected jumper and now it will no longer deliver spark. Could it be the jumper is damaging the ignitor circuitry? I know the positive wire is supposed to receive 12v so Im not sure what else could be causing this to happen? I dont see how I can be overvolting the system and Im not sure why the origional coil/points had failed....
