Droppin'Lunkers
- Jul 9, 2020
- 10
Hello all, this is my first post about my first voyage on my first boat.
I recently purchased a beautiful garage kept 1977 Marquis - stingray With less than 150 hours on the engine and routine maintenance kept up and documented.
However, about 30 minutes into my first outing the boat began to overheat and blew the water pump seal and steamed and leaked coolant from the weep hole. Also, the bilge was filling with raw water from
somewhere else and was mixing with the coolant from the weep hole.
luckily I was close to the dock so I let the engine cool down and emptied the bilge, then restarted it and slowly ventured back until it began to overheat again. I would shut it off around 170 and I repeated this process about three times until I got to my trailer.
I am not concerned I blew a head gasket and the engine runs beautifully and starts up first time. I do know I have to replace the water pump and the seal , and possibly the timing cover seal. i also suspect the heat exchanger is at fault but I'm hoping you all can tell me exactly what is going on.
my main question is where in the exhaust system is the raw water coming from in the bilge? Where in the exhaust system is this coming from??? I do know the coolant was leaking from the weep hole at various flows depending on rpms, and also from the reservoir cap.
so where is the raw water coming in from, what is the culprit , and what should my shopping list be? Engine is accessible to replace all of these parts.
I do my own repairs on vehicles and my father is an engineer who fills in the blanks on any issue. This is new territory for me and partly for him. Please help me solve this issue and I can send any pictures you may need.
thank you all
thank you all
