porkchop85
- Sep 19, 2016
- 8
Hi everyone I know of the opinion of the 470 engine but I got the boat in perfect condition for free. So here is the issue
1983 Seaox 230c with the much loved mercruiser 470
Under cruising speed about 3300 rpm after running for about 20 minutes sputters and dies with no warning. Temp was 165 normal oil pressure and voltage.
The boat will not restart for about 30 minutes to an hour. Cranks and cranks
After restarting the boat will run normally all day around 2000 rpms.
I replaced
coil
plugs
wires
cap
rotor
Removed points with ignitior 1 system
thought it was the ignitior1 system so replaced with igintior 2 system
No resistor wire
New Carb
5 inch cooler
exaust elbow
starter
alternator
Anything else I am missing?
I replaced
coil
plugs
wires
cap
rotor
No resistor wire
New Carb
5 inch cooler
exaust elbow
starter
alternator
