Boat engine was running great. Then I heard a buzz and the electric died to the motor and the dash gauges. I traced it back to the solenoid. Power in from the battery no volts coming out when key is turned in the ignition. If I jump the battery wire to the S terminal, starter engages.
i bought a new solenoid. Hooked it up exactly how the old one was. Then when I connected the battery the starter immediately engaged without the key in the ignition. I unhooked all wires to the ignition switch and it still did it. Then it stopped doing it and it is the same problem as before.
I think the new solenoid May have been bad when I got it.
any ideas?
any ideas?
